1.0.2 is the current version?
Stakes
Ok, so this may be asked and answered, but I looked and could not find it.
My iTunes says that my current version iPhone is the newest. It's 1.0.2, so am I missing something? I did not do the latest itune upgrade, and don't want to, but is that causing it to deny the 1.1.1 upgrade for the phone?
Again if this has been hit on, drop a link and accept an apology
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
1.1.1 is the most current firmware on the iPhone. I'm not sure if it's because you're using an older version of iTunes but it probably wouldn't hurt to upgrade. If that doesn't work I suggest restarting and then trying to update the iPhone again.
Tinman
4,334
183
Aridzona
I don't have a link, but I'd definitely wager that you need to update iTunes to get the 1.1.1 update. The security model used to protect the iPhone changed dramatically with 1.1.1, and iTunes had to get updated to support it.
Mike
seb481
Aug 3, 2007
774
San Diego
You need to update iTunes to its latest version. I had the same problem...
