1.0.2 to 1.1.3 feedback wanted
manishk123
Nov 29, 2007
116
Hi,
Has anyone successfuly updated/restored from 1.0.2 directly to 1.1.3 and unlocked and jailbroken?
1. Is everything working fine?
2. What method did u use?
Feedback will be appreciated.
Thanks.
manishk
Jan 2, 2008
22
yes i did it, everything working fine, i was first on 1.0.2 then I did 1.1.1 then 1.1.2 back to 1.0.2 upgraded to 1.1.3 using iTunes 7.6 then used ziPhone to activate, and jailbreak. and to unlock I used anysim 1.3 i airplane mode and thats it.
Also there are many post regarding the same check them.
manishk123
Nov 29, 2007
116
Thanks buddy! Will give it a go now. I've read the posts and got ziPhone on my comp too, but was just waiting to here from someone who's already done it. :laugh2:
Bobby Digital
Jul 15, 2007
noreboy
Feb 14, 2008
hey bobby i watch the thread you posted, looks very easy, but do i have to "RESTORE" or "UPDATE" i'm on 1.0.2. oh and by the way can i do this with ziPhone, my iPhone is hardware unlocked. :(
thanks.
akophone
Aug 1, 2007
300
Just upgraded to 1.1.3 from jailbroken 1.0.2 using ZiPhone under Leopard. I did the sync first, no restoring and then hyper spaced to 1.1.3. No problem here... so far! Everything seems to be faster... or is it my imagination....
Sep 9, 2007
11
I also went straight from 1.0.2 to 1.1.3 using iJailbreak. I did not however unlock the phone, just jailbroke.
The process was extremely easy, but the results need to be tweaked a bit still. My issues are still:
Customize doesn't work:
1. I changed all but my ipod icons (I have no clue why the ipod one wont change) using SSH, but the main thing is that I can't get 5 icons on the bottom row like I had before.
2. Youtube won't work.
3. Yahoomail gives me an error about my user/pass every time I try to connect.
Otherwise its been fine, NES works (after I put the games back on), the new features work, including the googlemaps finder thing.
I am still searching around about the issues above, but I think they will be worked out soon enough.
manishk123
Nov 29, 2007
116
thanks.
If you are using an unlocked phone clicking on the the Update button will give a failed error as your phone has been modified. You need to go with the Restore option.
manishk123
Nov 29, 2007
116
Hi,
There is a new version of ZiPhone (2.4) which claims to do everything with one click. Should I go ahead with that or should i select "don't unlocK" it will only activate and jailbreak. I can then use anysim..
What do u suggest?
noreboy
Feb 14, 2008
ok so i do a restore to 1.1.3 then use ziPhone?, does it matter if my iPhone was hardware unlocked?. i have 1.0.2 and modem firmware 03.14.06_G
thanks guys.
