1.0.2 to 1.1.3 is it SIMpler now?
manishk123
Nov 29, 2007
116
Hi,
Im still using my unlocked iPhone on 1.0.2. Is there a simple way of now upgrading to 1.1.3 now cause i'm not a very tech savvy person?
I heard of a software called ZiPhone with which u can unlock and upgrade to 1.1.3 with one click. Is that true?
Pls advise,
Thanks.
paulomb
Oct 1, 2007
72
Monterrey, MX
even if my 1.0.2 was unlocked with the first AnySIM? the one that used to mess witht he baseband?
will a restore and upgrade to 1.1.3 via iTunes will fix everything and then unlcok with ziPhone?
or will i get bricked trying to restore / upgrade?
manishk123
Nov 29, 2007
116
yes ZiPhone will unlock and jailbreak all in one click.
so let me get this straight.. I use iTunes to update my phone from 1.0.2 to 1.1.3 and then i use ZiPhone to unlock and jailbreak it?
is this the right way to go about it?
has anyone tried this yet? Pls let me know.
thanks.
themanofthedark
Jan 5, 2008
2,674
27
Boston
ok.
here is what you do.
restore to 1.1.3, that will do away with 03.14,
and put on 04.03,
then, you can run ZiPhone to jailbreak and activate,
then after that, go into installer, add the source "installer.iClarified.com"
go into install tab
click iClarified,
download and install anySIM 1.3
after that,
run anySIM in AIRPLANE MODE, as with 1.2.1
if you don't run in airplane mode, you will DESTROY your firmware, and will have to restart.
noreboy
Feb 14, 2008
same thing here?
ok , i have a unlocked 1.0.2 as well, i need to do the shift+restore to 1.1.3 and then run ziPhone?
do i need to virginize my phone before?
thanks a lot for your help guys
themanofthedark
Jan 5, 2008
2,674
27
Boston
ask yourself. what is a virginize? the rewriting of the baseband.
so, in that sense, you can just press the big restore button on iTunes, (upgrading will fail - just so you know), then use ZiPhone to jailbreak and activate, (I don't think ziPhone does BL3.9 unlocking), and use anySIM 1.3 to unlock (RUN IN AIRPLANE MODE).
download anySIM after you have restored to 1.1.3 and jailbroken, with iClarified's installer source. (installer.iclarified.com)
and 1.0.2? my condolences.
noreboy
Feb 14, 2008
thats great man thanks a lot for your reply.
one more thing, can i restore to 1.1.2 instead?
and doesn't ziPhone unlocks the iPhone too, i mean why do i have to run anysim?
sorry to sound newbie man
thanks a lot.
themanofthedark
Jan 5, 2008
2,674
27
Boston
AFAIK, ziPhone cannot unlock BL 3.9 phones,
and go to 1.1.3. its more stable, and IMO, its faster, and has the wiggly icons.
manishk123
Nov 29, 2007
116
Thanks for all the help themanofthedark.
But i'm still a little confused.. pls excuse if my queries sound silly to u.
Firstly, i don't understand what u mean when u say -
"restore to 1.1.3, that will do away with 03.14,
and put on 04.03"
What is 03.14 and 04.03?
Secondly, after i have updated to 1.1.3 and then run ZiPhone, will Installer still be on my phone or will i have to install it again.
Do i need wifi (net access) for this since my edge wont be working if the sim isn't working? because i don't have wifi in my office :(
"then after that, go into installer, add the source "installer.iClarified.com"
go into install tab
click iClarified,
after that,
run anySIM in AIRPLANE MODE, as with 1.2.1"
Finally, after i install and run Anysim in Airplane mode what do i do? I mean, do i have to use my phone in airplane mode all the time or if i restart after installing anysim i will be back to normal with 1.1.3 running on my phone.
I know these queries might sound silly to u, but your help will be most appreciated.
Thanks.
frankyfingerz
Nov 24, 2007
319
What is 03.14 and 04.03? firmware 03.14= 1.02 & 04.03= 1.1.3
also u think u can turn airplane mode after your done...i also have 1.0.2 with a little problem but trying to get to 1.1.3 once i'm done fixing my problem with my touchscreen,, please report back who everything works out
@manishk123
themanofthedark
Jan 5, 2008
2,674
27
Boston
03.14 = 03.14.08, the baseband for 1.0.2
04.03 = 04.03.13, the baseband for 1.1.3
and after you run anySIM in airplane mode, navigate to settings, and turn airplane mode off and you will have service.
manishk123
Nov 29, 2007
116
thanks for the reply buddy. Just one more thing.. Will Installer already be on my phone after running ziPhone on 1.1.3. Also do I require wifi to run installer to install Anysim?
Finally, is it ok to leave my non AT&T sim in the phone while doing this procedure. Thanks.
noreboy
Feb 14, 2008
great for all your help guys, but i just realized that my iPhone was hardware unlocked, can i still restore to 1.1.3 and use ziPhone or does this changes everything.
i'm very sad by the way.
thanks you guys.
