1.1.1 app issues.
Aug 1, 2007
1,232
44
Ok, just installed it, and got summerboard and installer to work, but the moment i open customize, mobilechat, nikotalkie, nothing is working.. nothings showing up in the summerboard besides customize and when i do open customize, it just shuts down... any tips I can use?
if you used installer for summerboard, you should delete and reinstall SB through ssh.
customize...i had the same issue and read several solutions. one, keep trying to open it. second, and this does sound weird but i think it's what ultimately worked, rub the screen a bit. it took about 4-5 times of trying to open it for it to work, but now it does and it works fine (though i seem to have to touch the screen each time to open the program).
also, have you restarted at all?
Ramesh
Jul 12, 2007
4,571
Irvine, Ca.
The simple solution that works. Reboot your phone. It worked for me, it can work for you. :D
