It saves the files into /var/root/Downloads on the phone. You can then use other software to email it off the phone or use an ssh connection such as iPhonebrowser and pull the file off the phone.
You can also view some of the downloaded files via MobileFinder and the rest of the MobileSuite (PDFViewer, Preview, etc). I'm using it right now and I love it.
As of right now, you can download the following formats (you may have to edit your Info.plist to add some of these formats):
.avi
.mpg
.mp3
.mpeg
.swa
.rar
.zip
.pdf
After you install the Safari Download Plugin, be sure to install CopyCoder's NetServices App, if you don't already have it. NetServices will allow you to turn on/off the Safari plugin on the fly, which is great for those times when you feel like streaming instead.
"Update: Version 0.2 posted.
New to 0.2: Progress bar. Basic instructional text. Allow user to choose name to save as.
Features tried and failed: Percentage and KB/sec as text. I have the value as a variable, NSString simply fails to display it correctly on 1.0.2"
I've installed it but can't get it to work.
I'm on FW 1.0.2
