1.1.1. to 1.1.2 problems
mo1176
Oct 19, 2007
I have stayed on 1.1.1. (installer is to good to give up.)
So i got OKTO PREP on installer and tried to upgrade to 1.1.2
When I did I lost everything it was like I did a whole system restore.
I did not want to lose installer so I downgraded to 1.1.1 again, and I am back to square one.
My question is What is the correct way to update to 1.1.2 and keep all my present phone features.
kariya9mdoa
Oct 26, 2007
80
1.1.1 - 1.1.2
Ok first you have to oktoprep in 111 then you download dev teams jailbreak jar and that will install ssh and installer so you will be ready to mod your phone. Then if your phone is locked you need anysim 121u it must be this one and you can get it from installer by adding the source http://i.unlock.no and then run anysim and you will be unlocked on 1.1.2
hope this helped you out if you have anymore queries just reply
HappyModding
Ps if you are using a pc the dev jailbreak also includes a pc jailbreak so just use that.
