1.1.2 jailbroken is now corrupt
vert
Dec 15, 2007
22
well ive had my jailbroken 1.1.2 for a couple of days, its been working well no problems, till today when i synced my iPhone on iTunes to put a movie on it, everything went fine, i ejected it, but i forgot to put another video in so i re plugged it in and it said my iPhone was unreadable and to restore, turns out the ipod app in the phone says no content so i do need to restore but heres my question, do i just restore and go to jailbreakme.com or what? im not sure if im starting from scratch here.
tiguy99
Nov 28, 2007
154
Chicago
I used this site to help with my 1.1.2 upgrade and jailbreak...it helped...
In essense, you'd have to downgrade to 1.1.1, jailbreak that by following the instructions here
http://iPhone.ranova.org/restore.shtml
then head over here once you're up and running
http://www.hacktheiPhone.com/112/iPhone_update_112_unlock_windows_1_easy.html
^ ^ works if once you have your iPhone jailbroken on firmware 1.1.1.
All you have to do is follow the instructions to the T up to the point they talk about unlocking. STOP there if your iPhone originally had 1.1.2 on it it asks you to unlock (which you DON'T want to do if your phone 1.1.2 firmware...at least not until there's a fix out)
