1.1.2: What The Heck Does It Do?
geordisjd
2,442
OK. I've updated. Everything is working fine. But what's new?
Can we start talking about the changes the upgrade brought, positive or negative? If there is a thread about this already, where is it? I searched but found nothing.
powersrus
Jun 21, 2007
326
Battle Creek, MI.
Sep 30, 2007
22
A "security update" to prevent people from using custom apps. but its already been jailbroke
Sep 29, 2007
348
Thus making it only usefull for iPhone users in Europe who speak different langauges.
There are a few things I have heard of such as a battery image in iTunes, and something with custom ringtones? Not sure if its put your own on but there is a section in the ringtones called custom.
stevetim
Jul 20, 2007
606
The battery status indicator is indeed next to your phone's name now in the iTunes list.
I don't see anything to do with "custom" ringtones
Ahh, custom ringtones section is under Settings/Sounds/Ringtone.
It is at the top of the Ringtone page and a separate window from the other ringtones.
I was looking forward too voice memos and disk access. Screw the people that told us we would have them.
psylichon
Oct 31, 2007
16,591
751
41
Philly
As I've mentioned elsewhere, the improvements I can see are:
Little battery icon in iTunes (whoopie)
Faster sync (contacts and calendar at least are waaaay faster)
Louder speakerphone (for calls and voicemail)
Custom ringtones (yes, you can put your own on... rename <30-second *.m4a files to m4r, drag-n-drop to ringtones folder in iTunes)
The mere fact that Apple has "unblocked" this last feature from the previous version is, I think, a sign that they will be easing up on control of the iPhone, which I think we can all agree is a very important thing...
They're throwing us a bone here, and I'm not about to complain!
eric325
Aug 7, 2007
51
i agree. the best part of the update is that we now can have our ringtone of our own choice instead of the dumb ringtone it came with. i hope this will last.
geordisjd
2,442
You can get full disk access, without hacks, for less than $10: get iPhoneDrive!
hotskate
Sep 21, 2007
314
34
i have 1.1.2 can someone tell me how to add installer.app on it?
Jul 22, 2007
When I logged into my work email I had to use the shift key. After the 1.1.1. update the shift key would stay on and I would have to turn it off. After the 1.1.2. update the shift key goes off after one letter is typed.
I hope that made sense.
Jul 24, 2007
Correct me if I'm wrong, but you no longer need to hack your iPhone in order to have custom ringtones?
If that is true - is there any programs out there which will help me convert it to 30 seconds and the proper iPhone ringtone format?
Hondamaker
May 14, 2007
9,946
671
56
Fairborn, Ohio
Audacity or Goldwave, to name a couple....
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
You need to double click on the shift key now. It will turn blue and stay on.
Jul 24, 2007
This might be a dumb question of mine but it's confirmed that I no longer need to hack my iPhone to put custom ringtones on now?
Just curious before I download and use Audacity or Goldwave. :)
You can fix that in Settings.
