1.1.3 Baseband; 1.1.1OOB, JB'ed 1.1.3
GP1138
Sep 26, 2007
98
What (dis)advantages are there in updating my baseband to 1.1.3 besides Google Maps' "Locate Me" working? Does anyone notice better signal retention, or any other decent updates?
How would I make it work with my JB'ed 1.1.3?
themanofthedark
Jan 5, 2008
2,674
27
Boston
never mind what I said earlier
didn't quite read what you said.
I don't know, because I have to run 04.02 for now because I have t-mobile.
if you have AT&T, go for it, it can't hurt.
GP1138
Sep 26, 2007
98
Ok, next step... how do I go about achieving this feat of strength?
I thought there was a provision in Installer, but I was mistaken.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
So you are already jailbroken? If you want to be jailbroken at 1.1.3 you can easily do that, BUT you must be jailbroken at 1.1.1 or 1.1.2 (preferable),
Are you PC or Mac?
GP1138
Sep 26, 2007
98
Are you PC or Mac?
I'm on a PC, and I used Nate's 1.1.3 jailbreak successfuly. I just want to update the baseband.
themanofthedark
Jan 5, 2008
2,674
27
Boston
ok, so you need to restore to 1.1.3, after which you will have 04.03.13_G as your baseband firmware.
afterwards, downgrade to 1.1.1, (you will have an error 1015 or 1013), jailbreak it using the *#307# method, after which you install oktoprep from installer, and upgrade to 1.1.2 using iTunes. you will still have 04.03.13, which is good. jailbreak it using idemocracy or whatever, and then use Nate true's method.
there - 1.1.3 jailbroken, with 04.03.13
themanofthedark
Jan 5, 2008
2,674
27
Boston
if your phone fails to boot after the downgrade (boots in recovery mode), download iphuc to your pc, and issue the following commands to get it out of recovery mode:
cmd setenv auto-boot true
press enter
cmd saveenv
press enter
cmd fsboot
press enter
then wait a few seconds it will boot.
Popdevil
Jul 2, 2007
254
It should be in the installer.
I have went through the guide and downgraded to 1.1.1 and then jb to 1.1.2. I have the installer. I see under SYSTEM in the install there is a 1.1.3 soft upgrade. Is this what you are talking about?
GP1138
Sep 26, 2007
98
No, this does not, to my knoweledge, upgrade the baseband, it is simply a component of Nate True's 1.1.3 jailbreak.
KNK
Jul 22, 2007
2,391
Stevenson Ranch
Are we talking about the BSD Subsystem?
Popdevil
Jul 2, 2007
254
I'm on baseband 3before8b (I think I'm good) I guess the question for everyone is, what is the step (link please) to have a jb 1.1.3 phone if you have a jb 1.1.2 phone with baseband 3before8b.
...or the bigger question may be, why should I upgrade to 1.1.3 since the SDK is coming out soon.
GP1138
Sep 26, 2007
98
Could you ask this question in another topic please? This has nothing to do with my question.
GP1138
Sep 26, 2007
98
The BSD Basband 2.0 is in the installer, I clicked it and it is there, I don't remember which category, prob systems.
Everything works fine.
BSD has nothing to do with baseband. It is a set of UNIX tools for the OS.
