1.1.3 Fix for iRadio !
iamse7en
Jul 27, 2007
140
Searched all over and found the answer:
SSH or in iPhone Terminal, type the following:
chmod 4755 /Applications/iRadio.app/iRadio
mkdir -p /usr/local/lib
ln -s /usr/lib/libstdc++.6.dylib /usr/local/lib/
Reboot phone, and I don't know why, but iRadio will work great! (THANKS TO DALLASNIGHTS)
Update: Had to enter it in twice, not sure why, maybe because of the newATTiPhone Space-limit fix, which royally screwed me over.
iShan
Feb 18, 2008
Hey nice to see you had the same problem as me, (nice? Maybe not) im kind of new to this Command stuff. is there anyways u can give me instructions on how make iRadio work i see u have those codes there.
Thank you so much if u can help. will appreciate it :)
Xphoid
Feb 18, 2008
edit: the reason was my wi-fi connection, everything is alright with the edge... thanks for this great fix...;)
i did it, actually the program didn't get back to spring board, but couldn't load the genres...
do u know the reason?
1<3Iphone
Sep 14, 2007
20
Easier Way
Hey, I just was able to do this - with a bit of magic ;)
1. Go to winscp - scroll up to the /root folder
2. Go to Applications
3. Right click on iRadio
4. Properties
5. In the box (usually has 0777 or some such) CHANGE TO 0755
6. Check box that says set permissions recursively (at the bottom)
7. Open up iRadio - should work perfectly!
iamse7en
Jul 27, 2007
140
4. Properties
I did that originally. iRadio still didn't work. I guess the method I found is a 2nd resort.
Feb 25, 2008
I tried this and iradio still does not start up. I checked all the permissions via SSH and all is right, the ibstdc++.6.dylib file is there and created but still no go..
Any ideas?
Feb 25, 2008
Wanted to add that i looked at the log files and this is the error that shows:
2008-02-25 13:49:59 -0500,109,0DE30769-E3EE-4F9E-AF4E-BDDE8A5831DF,23,iRadio,0x00000001, 0xe7ffdefe
<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE plist PUBLIC "-//Apple Computer//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
<key>AutoSubmitted</key>
<true/>
<key>SysInfoCrashReporterKey</key>
<string>6470627f5560057becec7bd06731ce6e716a5f7c</string>
<key>bug_type</key>
<string>109</string>
<key>description</key>
<string>Incident Identifier: 67A5CD5E-3064-44F6-9328-032F723F1D0B
CrashReporter Key: 6470627f5560057becec7bd06731ce6e716a5f7c
Process: iRadio [56]
Path: /var/Applications/iRadio.app/iRadio
Version: N/A (N/A)
Code Type: 0000000C (Native)
Effective UID: 0
Parent Process: SpringBoard [15]
Date/Time: 2008-02-25 13:49:59.442 -0500
OS Version: OS X 1.1.3 (4A93)
Report Version: 101
Exception Type: EXC_BREAKPOINT
Exception Codes: 0x00000001, 0xe7ffdefe
Crashed Thread: 0
Dyld Error Message:
Library not loaded: /usr/local/arm-apple-darwin/lib/libgcc_s.1.dylib
Referenced from: /var/Applications/iRadio.app/iRadio
Reason: image not found
</string>
<key>displayName</key>
<string>iRadio</string>
<key>name</key>
<key>os_version</key>
<string>OS X 1.1.3 (4A93)</string>
<key>system_ID</key>
<string></string>
<key>version</key>
<string>N/A (N/A)</string>
</dict>
</plist>
jamshid
Mar 21, 2008
