1.1.3 Jailbreak HELP !
Jul 4, 2007
I did the ziPhone jailbreak on my iPhone and it worked perfectly. but when i tried to do it to my friends OTB 1.1.2 it worked but i did not get the installer app to work. I don't know if it makes a difference but it has never been jailbroken before so I just wanted to know if anyone knew what i should do.
Thanks in advance
callisto9
Feb 12, 2008
403
IOWA
Thanks in advance
i think you have to be on firmware 1.1.3 to jailbreak using ZiPhone.
Nov 16, 2007
24
do a restore so it goes back to the non jailbroke 1.1.3 firmware state and then run ziPhone and it should work then. if i remember correctly it recommends that you be on a non jailbroken iPhone
