1.1.3 soft upgrade not showing
JewelDiamond
Sep 20, 2007
74
I have got through all the steps with Ibrickr and it tells me to go to the installer and install the 1.1.3 soft upgrade. When i go to find it in installer, it's not listed under system and installer doesn't ask to update.
Can someone tell me where to manual add it or what's going on? I need to know ASAP so i can unhook this iPhone from my pc.
Thanks in advance!
Tinman
4,334
183
Aridzona
Tap Sources at the bottom of Installer, then tap Refresh. This should get it to show up.
Mike
Tinman
4,334
183
Aridzona
It's distributed via Ste Packaging; a very common source. No idea why you can't see it.
Mike
JewelDiamond
Sep 20, 2007
74
Yeah, i think this is pretty strange i can't see it when thousands of others can. I did everything told to do, even delete all my apps before trying. Grr, so what should i do to get it to show?
JewelDiamond
Sep 20, 2007
74
the installer version i have is 3.0b9 .. i updated installer the other day before this 1.1.3 thing.
JewelDiamond
Sep 20, 2007
74
I tried to reinstall installer and that still didn't make this 1.1.3 soft upgrade show.
JewelDiamond
Sep 20, 2007
74
ok, well after several times of reloading the sources, it finally showed up, so if anyone else has this problem, just keep reloading the sources and it should show up.
