1.1.4 customize
Radis
Jul 3, 2007
173
i have a 1.1.4 jailbroken iPhone, and it will not allow me to download customize it says it is only for 1.1.(123) will there be an update to make it work with 1.1.4? and if so when?
thanks
Jan 19, 2008
21
you gotta download the 1.1.4 app patch first it tricks installer into thinking you still have 1.1.3 then download customize, then uninstall the 1.1.4 app patch, then set customize permissions to 775, then enjoy.
Radis
Jul 3, 2007
173
add source: ride4.org/shai.xml
install "all sources" you get like 94 of them
then you'll see it in all packages its near the top because it starts with numbers "1.1.4 apps patch"
i can not get this to work the 1.1.4 patch does not show up?
any help?
dolo
Jun 29, 2007
23
NYC
Sorry for the noob question...
Steve, where do i go to include "add source"? I went to the "source" icon but only saw an edit and no option to add a source?
Also - what's the quickest way to re-virginize this sucker and remove any and all instances of a jailbroken iPhone? i jb'd my buddies phone and he's pretty angry about it.
Thanks in advance.
Regards,
dolo
lman
Oct 18, 2007
632
I can't find the custom customize in the installer and i added the source...any ideas?
lotecorp
Mar 3, 2008
32
The reason for that reply is because I thought the forum rules state no sources. If I am wrong, sorry. Please post any solutions unless against forum rules
gremlok
Nov 18, 2007
just upgraded to 1.1.4 and installed sumerboard. but it doesn't seem to work at all.......do i have to 'activate' it the first time or what?
ok has anyone got customize to work on there iPhone 1.1.4 i got summerboard to work now need customize to
