1.1.4 iPod Touch Installer!
Azteka
Jul 10, 2007
64
The 707
how can i get installer on an jailbroken 1.1.4 ipod touch?
i already jailbreaked it and installed Cydia with iLiberty+ but i did not like cydia at all....and i need to get installer on there....how can i do it?
im familiar with Winscp but can someone tell me the process?
chcorey52
Dec 25, 2007
556
I just jailbroke mine with ZiPhone 3.0 and got installer. You restore it and just connect it to ZiPhone and press jailbreak. What i don't understand is if you already jailbroke it how you don't have installer because that is what jailbrekaing does?
Azteka
Jul 10, 2007
64
The 707
well i jailbraked it with iLiberty+ because i heard ZiPhone didn't do a good process on a 1.1.4 16GB iPod touch....iLiberty only had the option of having Cydia installed....but i hate cydia...installer is so much simplier...how do i get it on there!
chcorey52
Dec 25, 2007
556
whats cydia? all i know is that if you don't want to do ziPhone there is ipwnage to use. ive heard that is safer and still very simple. just research around a little bit. good luck
themanofthedark
Jan 5, 2008
2,674
27
Boston
connect to computer.
open up iPhonebrowser
find Installer on Internet.
shove installer into /Applications.
reset iPod.
you're set.
davis5050
Aug 18, 2007
192
Is it just that nobody knows how or no one wants to help me? I have been trying for 6 days to get a answer to this question. I did the search and tried the methods that I found to no avail.
chcorey52
Dec 25, 2007
556
Restore/set up as new in iTunes/ run ziPhone 3.0 press jailbreak/sync all of your music and stuff
davis5050
Aug 18, 2007
192
I have tried to break it 2 times with ziPhone and all I get is script running down the screen for 10 mins then I have to do a restore so something is not right, my iPhone broke in just a few mins with ziPhone.
