10.10.3 Beta
Dec 15, 2008
5,386
340
27
Pensacola, FL
Please do not install this 10.10.3 beta if you have the opportunity to if you are in the program. It causes coding to appear everywhere on the screen and then it crashes when you try to login, and then goes back to login screen. You won't be able to get to desktop. :p
If you care to know, it brings Photos to the Mac...that's the main thing besides fixing stability etc...or in this case adding more instability. :eek:
Dec 15, 2008
5,386
340
27
Pensacola, FL
I fell asleep while it was installing. It did its thing and rebooted it looked like. I turned on computer and logged in and then it showed a bunch of coding again and then crashed back to login like before.
Worked for my friend.
Dec 15, 2008
5,386
340
27
Pensacola, FL
Really? You're giving up on the whole shebang? There are a lot of people running the beta just fine. Try Googling and find out if others are having the same problem you are.
I have done that and all I see as it's only just recently come out, is news about it. My friend installed it fine on his Macbook Air. Maybe it's an issue with my early 2011 Macbook Pro? I doubt that. I've been able to install beta since day one. Maybe this beta is causing issues for my early 2011 laptop and is the same for others with that aged computer and Apple will look into it? Who knows.
For the record, I didn't just try to install it once.
28,365
5,506
Why don't you just restore to 10.10.2? You could try the beta again after that if you wanted.
28,365
5,506
Boot into verbose mode and uninstall your virtual machine software if you have the beta installed right now. Otherwise, just uninstall the virtual software while on 10.10.2 and and then try the beta again. Post your kernel panic log (/Library/Logs/DiagnosticReports) if you continue to have trouble.
Dec 15, 2008
5,386
340
27
Pensacola, FL
I guess I should have said I've been using my main profile for beta. My friend does the same thing and uses it for anything he does. The only difference is that he's on a Macbook Air.
I've had no issues installing other beta.
Dec 15, 2008
5,386
340
27
Pensacola, FL
I am finally on 10.10.3 after erasing everything and going all the way back to Snow Leopard, doing the updates etc etc, going to Yosemite, signing in blah blah then installing 10.10.3. I know, you're probably thinking...hours for all that just to get to a beta? Well, I'm happy. The issue was bad installation still in the system and the only way to erase it was to do what I did.
