10 Ways To Save Battery Life In iPhone
iLiam
Dec 18, 2008
53
Chesterfield
My biggest complaint about the iPhone and iPod Touch is the battery life. During heavy usage you can’t even get a full 3 hours out of it. The best thing you can do is know what to look out for. . .and hopefully this list will help. And I hope Michael will make it a sticky so everyone can see it! Because its one of the most important factors of iPhones and iPods of today.
10) Keep It On
There really isn’t any reason turn it off at the end of the day. As long as it is in ’sleep mode’(without playing music) it turns all network activity off. The device actually uses a lot of the batter just to turn it on. . .even more than if you had just left it on.
9) Turn Sound Effects Off
You can go into Settings -> General -> Sound Effects and turn it off. Or at least set it to either Speaker or Headphones. . .not Both(which it is by default).
8) Turn EQ Off
You can go into Settings -> Music -> EQ and turn it off. This will use less resources to monitor the EQ.
7) Less Email Addresses
You can go into Settings -> Mail and disable a few of your email accounts. The less email addresses your iPhone or iPod Touch has to check, the more battery life you will have. This is because of network activity usage.
7a) Check Email Less Often
You can go into Settings -> Mail -> Auto-Check and set this to manual. . .or at least Every hour(as opposed to 15/30 minutes). Just like above, the your device has to connect to Wifi/Edge the longer your battery will last.
6) Set Auto-Lock
You can go into Settings -> General -> Auto-Lock and set it to 1-3 minutes(I have mine set to 1). The longer your screen is turned on the more it uses the battery. Either do this or get used to putting it into ’sleep mode’ immediately after usage.
5) Turn BlueTooth Off
You can either do this via Settings or in the BossPrefs application.
4) Keep Brightness Dim
You can go into Settings -> Brightness and move the bar on the top toward the left. Go as far to the left as you can(without sacrificing quality). The less bright the screen has to be the longer your battery will last.
4a) Turn Auto-Brightness Off
You can go into Settings -> Brightness and turn Auto-Brightness off. This will not only prevent the device from increasing the brightness level. It will also use less resources. . .since it doesn’t have to monitor anything.
3) Turn Edge Off
Much like BlueTooth, you can do this from either Settings or the 3rd party application BossPrefs.
2) Turn SSH Off
You can go into the application BossPrefs, Services, or the default SSH icon and turn this service on/off. This runs in the background when any network activity is available. This is one of the biggest reasons people who Jailbreak their iPhones and iPod Touches have very poor battery life.
1) Turn WiFi Off
Even more than SSH, WiFi really uses your battery. Paired with MobileSafari browsing, your battery will not even last 3 hours. I normally just put the device into sleep mode, and it turns of WiFi automatically. But, when music is playing WiFi is on, and it will deplete your battery with the quickness.
This is a lot of things to monitor. . .but if you get into the habit of turning services on/off(much like turning off a light when you leave the room). . .you could go an extra 2-3 days between charging sessions.
Bonus
At least once per month try and use all of the battery life in your iPhone and iPod Touch. The lower you get the battery level the better. Then recharge your device to 100%. This will ‘reset’ your battery to the best of it’s ability. The more you recharge your device, without letting the battery die completely, the lower your ‘battery capacity’ is. Doing this once per month(or even once per week) will keep your battery in tip top shape.
Good Luck and I hope this helps
Thanks If it helps :)
iconone
Apr 8, 2008
1,148
35
Clear Lake Texas
3) Turn Edge Off
How do you turn edge off on a stock iPhone? Are you talking about 3G turn the 3g off?
Picazzo
Jan 21, 2008
2,808
Copenhagen, Denmark
3) Turn Edge Off
I'll guess it must be the "Airplane Mode"....lol
dturner
Dec 15, 2007
5,725
Louisville, Ky.
What the heck is this? LOL
Good post though, especially for the new people here.
alamarco
Nov 28, 2008
162
Canada
myfigurecollection.net
3) Turn Edge Off
Yeah, you can't turn off Edge on an iPhone that isn't jailbroken. You can turn off 3G, but that's it. Personally, turning off 3G is a waste because when you go out you have to re-enable 3G and that would just be really annoying to have to keep doing over and over.
Picazzo
Jan 21, 2008
2,808
Copenhagen, Denmark
And you're sure the battery is fine by "3G always on"?
iconone
Apr 8, 2008
1,148
35
Clear Lake Texas
When my 3g is on it eats my battery. 3g on I get about 3 -4 hours. 3g off I get about 6 hours.
iLiam
Dec 18, 2008
53
Chesterfield
With 3G on my phone lasts me 1-2 days without needing a charge. That's fine by me as with 3G off it's not going to last another day.
Thats good going a lot of my friends - it lasts them about 8 - 12 hours
iconone
Apr 8, 2008
1,148
35
Clear Lake Texas
That's crazy out of both my iPhones I have never got more than 10 hours out of mine.
