12.9 question
KevTN
Jan 16, 2011
47
I am really thinking about getting a 12.9 ipad. my questions are simple but may determine my decision.
1) how does it travel? My daughter does travel softball so we travel all over the country, sometimes drive and sometime fly. I am concern with the size it would be easier to break..
2) Everything I read says the 12.9 is diffcult to see in the sunlight...how good/bad is the 12.9 to see in the sun?
3) Without the keyboard how difficult is it to type using the built in keyboard?
thank you
Leo
Nov 9, 2008
900
137
43
30
Calgary, AB
Hi KevTN,
Fellow 12.9 iPad Pro owner here.
1) Depends on your case and bag. I have a 13" MacBook Pro bag from Incase and the Smart Cover and Smart Case for my 12.9" iPad Pro, and I have to say it's worked wonderfully for me. I take it around everywhere as a lot of times I find I just wanna suddenly sit down and draw when I'm in the mood.
2) Turn up your brightness, and you should be fine.
3) The built-in keyboard is actually REALLY GOOD, it's the same size as a full-sized keyboard. The question is, are you comfortable typing on a touch screen display? If so, you'll be fine.
Mrallank59
Jan 8, 2013
252
31
I like the 12.9 but the 10.5 won out in the end. The size just felt perfect to me
Mrallank59
Jan 8, 2013
252
31
I’ve had the 10.5 for a year. I’m also thinking about moving up to the 12.9
Sent from my iPad using Tapatalk
