16g vs 32
lift603
Jun 23, 2009
23
I am currently a verizon user but plan on switching to AT&T to get the iPhone3gS
how many more songs and videos can you hold on the 32 compared to the 16
if i only plan on putting way under 100 songs on it should i just get the 16? or would the 32 to be nice to have for resale value
5,578
They both hold their value well. I got the 32 because the phone does video recording, which uses a lot of space. I had hundreds of songs, 50 or so apps, and a few movies on my 16 GB 3G and still had lots of free space.
greenjbhsd
Jul 13, 2007
571
If you main requirement is 100 songs the 16 is just fine. I subscribe to the "get a little more then you need for room to grow" mentality and would still recommend the 32. You will have the phone for 2 years (theoretically) and over time you might see the size of apps growing. The extra space will be peachy in that case.
6,682
49
I have 768 songs, about 65 apps, and 3 movies. I still have 7.2 GB free space on my 16GB 3G.
Honestly, I went with the 16GB 3G phone because I was close to using up all the space on my 8GB phone. I prefer to have at least 2GB free no matter what for the OS to use as a swap file and to help prevent crashes from full memory.
