1PC - 2 Apple Products - iPhone + Nano = How to sync both?
Owgasm
Jul 12, 2008
177
Hey,
As per title, i've got 2 Apple devices.
iPhone 3g and a new nano for my mum.
I'm using 1 pc and iTunes.
Is there anyway to create like 2 users in iTunes?
So i have 2 different library and don't have to copy my iTunes music files and paste somewhere after and put in another selection for the nano.
Woofus
Hey,
Sure...
Just hold down the shift key when you start iTunes. Keep holding it until you get a dialog box. It will ask you to either choose a library or create one.
Make mom her own library.
Then when you start iTunes, you'll need to hold the shift key and then choose which library to use.
Marianne
2,326
Massachusetts
marianneschultz.com
You don't necessarily need to create a separate library - iTunes will recognize the Nano as a completely different device and you can choose what playlists or songs to sync to it and it will not affect the syncing of your iPhone at all. I sync 1 iPhone and 2 Nanos to my single iTunes library with no problems.
dturner
Dec 15, 2007
5,725
Louisville, Ky.
Same method I use. I just drag and drop for the nano.
uanimal
Mar 23, 2009
what if i need to syn 2 iPhone to 1 PC? how does the PC differentiaite the 2 different set of contacts in outlook for 2 different account ?
