1v car chargers don't work on 3GS?
Rhinohd
Sep 20, 2007
105
So my Alpine radio and my griffin car charger will not charge my new 3gs.
Am I doing something wrong?
They both play music I just get a message that it will not charge on the phone. Its upsetting since the battery life stinks on the new phones...
whale_hunter
Sep 11, 2007
207
My $20 V1 charger works just fine , not sure why some other adapters don't.
Rhinohd
Sep 20, 2007
105
Anyone else having this problem?
fury
Oct 23, 2007
2,274
238
33
Louisville, KY
If I remember correctly, the 3g and 3gs removed the FireWire charging capability. If that's what your adapter uses to charge, you're out of luck.
Staszek
Sep 24, 2007
212
It depends on if the company that made them made them USB or Firewire.
Starting with the 3g Apple removed the extra connect that allowed for both firewire charging and USB charging. Now they charge via USB only. Some chargers still use the old firewire standard so they wont charge a 3g or 3gs but will charge the orginal V1 iPhone.
Rhinohd
Sep 20, 2007
105
Well that explains it but still stinks. Thanks!
Mike12000
Oct 22, 2007
116
Southern Illinois
Well, I think you all inadvertantly answered one of my last two remaining questions before I order a 3GS. I have a 2009 Honda Pilot (Touring) with a USB port to play my iPhone music. It's tied into the GPS Nav screen so I can control everything from my console. It's a sweet setup, I love it. Anyway, I was concerned whether a 3GS would be compatible with it. It doesn't sound like I'll have any problems. Thanks.
I'll start a thread for my other question. Others might be interested in the subject.
psylichon
Oct 31, 2007
16,591
751
41
Philly
Well, I had a AA battery charger for my V1 that also worked for 3G, but does not work on my 3GS now.
Kuntry
Mar 26, 2009
318
Las Vegas
http://www.scosche.com/products/productID/1667
Scosche Passport Charge Converter. I've used this for about 4 months with my 3G and it also works great with my 3GS. I bought a generic ipod charge+audio to RCA cable from Circuit City before they went out of businesss and I went home and hooked it up in my pickup and no charge but GREAT audio sound so i bought this and all is well. I'm thinking of getting a 30-pin Dock Extension cable and putting the passport in the dash and just running the extension out as the passport is sort of bulky but it works great for now. It allows all pins to be routed through but on the charging pins it uses resistors to drop the voltage down from 12v firewire to the 5v USB power.
Rhinohd
Sep 20, 2007
105
Thanks! just picked one up on ebay for $24 shipped.
Rhinohd
Sep 20, 2007
105
just got my Scosche Passport Charge Converter and NOPE don't work with my Alpine head unit. I get an error message and it causes huge amounts of distortion.
Wtf0ver
Jul 2, 2009
33
Just found out my dlo iPhone charger doesn't work with my 3gs. Kinda sucks. I think I will just use the ac adapter the phone came with along with the plug in outlet adapter for my vehicle
