2.1 maH, 4.2maH, 5W, 10W. HELP!
frldyz
Aug 10, 2014
New iPhone owner/user (5s)
I love this thing. I don't know why I waited so long.
I use this thing constantly through out the day. And the battery needs recharging through out the day.
Im planning on investing in multiple wall charger, car chargers, and an external portable battery recharger and lightning cables ( hyperjuice.. morphine.. )
1. The bigger the number in maH for your car cigarette lighter the faster the charge?
For EX: a cigarette USB charger with a 2.1 maH is going to charge faster then 1 with 1maH? And a 4.2 maH will charge faster then a 2.1maH?
2. If a cigarette USB charger has dual ports and is rated at 4.2maH. That's 2.1maH each USB port?
*Now is that 2.1maH when both ports are in use? What if you are only using 1 port? Is it still 2.1maH or is it 4.2maH? I ask because the guy @ B.B told me this?
3. What are some of the better quality lightning cables I want to buy? Will all lightning cables charge the device @ the same speed?
4. When using an external portable battery recharger such as hyperjuice or morhpie: This is just a charging device correct? You charge the charging device. And when needed you just connect your phone to the device and it will charge the device as if it were connected to the computer via USB or connected to the wall?
.......so confusing......
Thanks guys.
I've done multiple searches and got lots of conflicting info.
frldyz
Aug 10, 2014
PS: I am using an Otterbox Armor case ( love it ). I am aware they make cases that have extra battery power. But Im not planning on ditching my Armor
chris
Administrator
Administrator
Jun 10, 2006
11,812
1,778
Long Island, NY
I'll take questions three and four. I've purchased numerous lightning cables including Apple OEM, MFi (Made for iPhone) and cheap unauthorized cables. The cheap cables are hit or miss. There are also reports they can damage your iPhone, though I've seen no evidence of this personally. The OEM cables are expensive and in my opinion, not worth it. The MFi cables mean the manufacturers conform to Apple's standards. I've found them to be quite good. I'm particularly fond of the Arduro cables. The connector has a nice grip to it, longer than the OEM cables. With any of these cables, look for sales. I've been watching various deals and ordering extra cables.
There are a number of battery cases. They'll charge both the case and iPhone. I have a Lexmark that uses a microUSB. People seem to love the Mophie cases. I reviewed an older Mophie here.
As for charging, I've never been particularly worried about different charging specs. The iPhone charges faster than most phones, in my experience.
28,365
5,506
1. & 2. No. You can only charge the iPhone at 5 volts. Cigarette chargers are 12 volts. The iPhone will only allow 5 of the 12 volts to protect it from overcharging. So, to answer your question, they will all charge it at the same rate.
3. I recommend sticking with Apple certified cables or OEM (official Apple cables). They should all charge at the same rate, but the cheap knockoffs can break or stop charging as soon as a couple weeks after purchase.
4. Yes.
28,365
5,506
Also, if it's within your budget, check into getting a car stereo that has a USB input. They only cost about $100. They're nice because they charge and play music and navigate with just one cable.
ricks2gtouch
Feb 20, 2009
585
162
43
I just replaced the stereo in my old car with one that has BT and a USB port. In addition to charging and music, I can also control Pandora thought the stereo when connected. Nice.
chris
Administrator
Administrator
Jun 10, 2006
11,812
1,778
Long Island, NY
We had a road trip yesterday and had cables every where. Years back, we had the audio plus charging hook-up using the older connection. It was so long ago, it was the first install of this type for the car audio store. It was awesome.
28,365
5,506
I got a new BT/USB car stereo a couple weeks ago and it has Pandora capabilities as well. I just installed the Pandora app and PandoraSkips (Cydia app to enable unlimited skips) last night and I'm going to test it out today.
frldyz
Aug 10, 2014
Chris
What about maH, does it make much of a dif. if its 1maH, 2.1maH or 4.maH etc.....
Chris the Arduro cables look good.
I have an otterbox armor case.
Do you think if I trimmed down the end of the plactic near the connector it would fit into my otterbox armor?
28,365
5,506
Chris
I don't think Chris answered questions 1 or 2. See my reply where I answered them. It doesn't make a difference. It will only charge at 5 volts.
You might be able to shave it down a bit with a dremel. I shaved a bit of plastic off both sides of my 0.2 meter 30-pin to Lightning adapter with a dremel to get it to work with my Element Sector 5. Here's a picture that shows how much plastic I removed:
frldyz
Aug 10, 2014
Europa: Thanks for all the great useful info.
Now that I understand it is limited to 5v that makes it a lot easier to decide.
1. How about the ipad mini? Is that limited to 5v?
Made a small little purchase lastnight on amazon for around $60.
1 xcc dual USB 4.2Amp 20W smart high capacity wall charger
1 scosche USB 242M 12W dual USB car charger
1 Arduro 10' lightning cable
1 Insignia 10' lightning cable
I also bought a Hyperjuice plug 18000MaH from their website for $112
frldyz
Aug 10, 2014
Europa: Hows Watts come into play when it comes to charging?
More watts from your wall charger or car charger faster then a lower wattage item?
up10ad
Aug 1, 2007
3,608
468
Fruita , CO
up10ad.com
The important issue with charging isn't so much the voltage (as you mention, they all use 5v), but the Amperage/Wattage. Bigger batteries like the iPad need higher Amp ratings in order to take a charge in a reasonable amount of time.
The formulas are:
AMPS = WATTS/VOLTS
WATTS = AMPS x VOLTS
The iPhone charger is 1 amp/5 watts while the iPad charger is rated 2.1 amps/10 watts. Keep in mind that a standard USB hub/port delivers only .5 amp/2.5 watts, which is why charging takes so long via standard USB.
So, bottom line is you want and need a higher Amp/Wattage charger for an iPad in order to get it charged in a reasonable amount of time. Always check the specs on a car charger to make sure the output (on each port if it has more than one) meets your needs.
