2.1 Update-PLEASE HELP!
Jul 11, 2008
67
Hi,
I just purchased a first generation iPhone, brand new in package, and want to unlock and jailbreak it to use on T-Mobile. The phone is running on 1.1.4. Can I go from 1.1.4 to 2.1, unlock and jailbreak, all in one step, or will I have to do something extra?
I currently have a 4gb running on 2.1, T-Mobile, but just purchased a 16gb because I can't fit all my apps and music, etc. on the 4gb.
Thanks,
Laina
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
I would recommend restoring the new 16 GB iPhone and upgrading to the 2.1 firmware. I would then suggest doing the Jailbreak and Unlock using either QuickPwn or WinPwn. That will clear out anything (well, most anything) from the previous owner and then get the phone working on T-Mobile again.
Jul 11, 2008
67
Hi,
Thanks for your response. To do the first thing, do I just connect the phone to iTunes 8.0 and click on update, or should I click restore too? Do I put my sim in before I do this or after? I am familiar with doing the QuickPwn, just not sure about the first part. Thanks again!
Youngbinks
Jun 4, 2007
7,617
31
Atlanta, Georgia
Hi,
I do not believe that your SIM card is in danger, but it won't be a bad idea to take it out just in case. I would choose Restore and go back to factory settings because if you Upgrade then it will attempt to upgrade the unlocked firmware and that could cause the phone to brick.
After you restore I believe iTunes is going to tell you that your SIM card isn't the right kind or that it is just not there, either way, you're fine. Now you want to run the Jailbreak software that will allow you to activate the phone on T-Mobile and get it up and running. After you run the QuickPwn or WinPwn you should be all good to go.
jsntrenkler
Sep 22, 2008
942
Tucson Arizona
Very sound advice, and very helpful.
