2.1 update problem\WiFi
CanSpec
Mar 5, 2008
151
I just updated to 2.1 and now my wifi connection keeps dropping?:(
psylichon
Oct 31, 2007
16,591
751
41
Philly
Try resetting your network settings. If that doesn't work, reset all your settings. If that doesn't work, then restore. If that doesn't work, call Apple.
I think that about covers it. Start with the easy options first.
CanSpec
Mar 5, 2008
151
Thanks. How do I reset network settings?
theevilone
Dec 30, 2007
85
When that happens to me it's the router so I reset the router and then it works.
GZL
Sep 27, 2008
I have the same problem. However it is not the phone. I have two wi-fi access points, same key, same encryption same everything but two different brands. On the one it drops the connecetion all the time and the other never. Some investigation pointed me into the direction of firmware upgrade. I have not yet done this as I am happy with my second access point. Hope this helps!
Dec 18, 2007
29
Danbury, CT
I had the same problem. I brought it to the Genius Bar and they wound up giving me a replacement iPhone.
