2.2.1 to 3.0.1
rklucznik
Jun 15, 2008
Hey guys how do I got from 2.2.1 to 3.0.1 now that 3.1 is out? Thanks for your help
RagzMan
Sep 16, 2009
Salt Lake City
I just did this a couple of days ago - I used QuickPWN to do it. Pretty easy. You can find the instructions here: http://www.quickpwn.com/2009/07/jailbreak-and-unlock-iphone-301.html
The only thing I was a little confused about was having to download the 3.0 firmware after I had just installed the 3.0.1 firmware on my iPhone. But, you just need to download 3.0 to run the QuickPWN tool. You don't actually install 3.0 - QuickPWN just needs it to run the program. That link above should give you what you need.
RagzMan
Sep 16, 2009
Salt Lake City
Battery drain
Forgot to mention - beware of the battery drain. There are a ton of threads on the battery drain issue with 3.0 firmware, but I had to turn off push for Outlook e-mail to get my battery to work as normal. I think there have been a lot of different 'fixes' for different people, but that worked for me. Kind of a bummer that I had to turn off the push.
