2.2 jailbreak released.
failsafe
Oct 17, 2008
153
San Diego
I haven't tried it yet because I have too much to do tonight. Will try it out tomorrow.
Looks like this is safe only if you don't need to unlock the phone in the future.
http://blog.iphone-dev.org/
  1. GOLDEN RULE: If you have a 3G iPhone and want potential soft unlock in the near future do NOT use QuickPwn, and do not use the official ipsw or the iTunes update process without using PwnageTool.
  2. Read item 1 again and again.
  3. At the bottom of this post are the bittorrent files for the latest versions of PwnageTool and QuickPwn.
  4. These are suitable for the recent 2.2 release.
  5. Please read all parts of this post before downloading and using these tools.
  6. The ‘late 2008’ MacBook/air/pro line of computers have an issue with DFU mode, it is possible to go from Pwned 2.1 -> 2.2 but going from stock to Pwned does not work, if in any doubt use a different machine.
  7. Choosing the correct tool is crucial. Be warned!
Baseband 101
The ‘baseband’ is the generic name given to the internal components of the iPhone that handle the phone calls and Internet access. This ‘baseband’ is a tiny and unique independent computer system that runs inside your iPhone, it is separate to the main system that handles the applications (such as email and google maps) and it talks to the main part of the phone over an internal communications network. Think of it like a cable modem or other peripheral that is attached to your home PC that needs occasional updates. When a software update is released and presented to you within iTunes the baseband is sometimes updated (to fix bugs or add new features). The 2.2 update for the iPhone 3G contains such an update, so running the vanilla updater straight away with iTunes will reprogram and update the baseband. This could be bad for certain people, depending on your ultimate aim.
SIM Free/SP Unlocked/Factory Unlocked iPhone 3G
This applies if you bought your iPhone 3G for $$$$$$$. This model of iPhone 3G doesn’t have an Service Provider lock (aka factory unlocked) and you are able to put any SIM card into the phone and get service. Your phone is already unlocked so you do not need to worry about baseband updates, simply upgrade to 2.2 using iTunes and then use QuickPwn to Pwn and Jailbreak. This will add Cydia and Installer too.
Locked iPhone 3G - Preserve Baseband
This applies if you have a locked iPhone 3G and you wish to update to 2.2 but preserve the iPhone’s current baseband software. Preserving the baseband will give you the maximum chance for any upcoming software unlock. To upgrade your phone to 2.2 and preserve the state of the baseband you need to create a custom .ipsw with PwnageTool. This custom .ipsw will not contain the baseband update but of course will still allow all the cool new stuff from 2.2.
There are plenty of tutorials about this process on the web, but PwnageTool contains intuitive graphics and easy to follow prompts that should have you up and running in no time at all.
Locked iPhone 3G
If you are using your iPhone with one carrier and have no interest in the possibility of an iPhone 3G unlock in the near future then just restore or upgrade to 2.2 using iTunes and use QuickPwn to Jailbreak and add Cydia and Installer.
Locked iPhone 2G (1st Generation)
Restore your iPhone 2G with iTunes then run QuickPwn to do the magic, ‘nuff said.
iPod Touch 1G (Original iPod Touch)
Update to 2.2 with iTunes and run QuickPwn.
iPod Touch 2G (New iPod Touch)
Sorry, no support at this time.
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
Here are the links to save you some time! :)
Bittorrent Releases
  • PwnageTool 2.2 for Mac OS X ishere SHA1 Sum - 97ee6096aaa1967498431bf01c36c18d0e877545
  • QuickPwn 2.2 for Mac OS X is here SHA1 Sum - 254b8af0e19870a4660b7b11e3b6f6ae1d6bc66f
  • QuickPwn 2.2 for Windows is here SHA1 Sum - ffdbc561224c61ffc2713cb6a6e696b6d429c4ca
Unofficial Mirrors
The following links are unofficial download mirrors, you download these at your own risk, we accept no responsibility if your computer explodes or if it becomes part of a NASA attacking botnet or even worse if your hands fall off mid-way during the use of these archives. We do not check these links or archives. Always check the published SHA1 sums. We would prefer that you downloaded the official bittorrent release that is linked above, but you are welcome to try these if you really must. Mirror owners should email direct links only to blog@iphone-dev.org , please don’t place mirrors in the comments as they will be deleted.
Mac PwnageTool
Mac QuickPwn
Windows QuickPwn
nerdkill
Nov 16, 2008
17
i'm tired and confused
all i want is my phone to be jailbroken, i have AT&T and i'm not switching as i just started my contract. so does that mean that i can update to 2.2 and then just quickpwn again with the link above? i'm sure my question is retarded to most people, but i just want to make sure i'm doing things right so i don't do anything stupid. thank you!
15,385
1,089
my Pwnage tool keeps failing to create the .ipsw... tried it three times now.
I guess i'll give QuickPwn a shot.
i'm using a v1, btw.
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
Naw it's not retarded. The answer is yes. I'm in the process of jailbreaking right now.
failsafe
Oct 17, 2008
153
San Diego
You can jailbreak as long as you don't need to unlock the phone in the future. Since you're staying with AT&T you are fine to JB. You will need to upgrade to 2.2 and then download the new version of quickpwn which supports jailbreaking for 2.2 firmware (links listed above in cliffeman's post).
15,385
1,089
quickPwn worked great on my v1. reinstalling Cydia apps now...
psylichon
Oct 31, 2007
16,591
751
41
Philly
How's the boot time? Lag? How many seconds does it take to open camera, SMS, settings, and iPod specifically?
15,385
1,089
opened Phone (and contacts), SMS, Settings, Camera, iPod, and Safari. All were up, running, and responsive in under 3 seconds... camera being the only one that had an appreciable lag... took about 2 seconds for the aperture to open. Then again, i haven't installed anything yet. Just 2.2 pwned with Cydia and Installer.
Saverino
Jun 1, 2008
4,480
92
Burbank
I can't wait til I get home! I'm at Disneyland right now. :cool:
ZR_Yancy
Jul 11, 2008
3,982
737
NOTE: ‘Simple Mode’ in PwnageTool currently only works for the iPod Touch. To use PwnageTool for iPhones you will need to use ‘Expert mode’. This is a workaround while we make an update and fix this issue. In order to do this you will need to navigate to the ‘General’ window and change two things: Deselect ‘activate’ ONLY if you are normally able to activate through iTunes (but if you wish to ‘hacktivate’ the iPhone using PwnageTool then leave it selected). You will also need to change the partition size to about 1000MB (type in the value or use the slider).
‘Hactivate’ means to activate the iPhone yourself without Apple. This is used if you live outside an officially supported region and cannot activate the phone using iTunes.
15,385
1,089
that would be why it didn't work for me. you'd think they'd mention that little detail in the program. Clever guys.
eureka
Jun 19, 2007
62
how do i make the cracked ipa work with the new 2.2 jailb
