2 easy questions for you.
jimmyjimmy64
Sep 27, 2007
39
I just got my iPhone. I just plugged it in.
1. How can I tell that it is charging?
2. how do you take the plug out of the iPhone? Do you just pull it out?
Jason
jptolife
Jul 15, 2007
645
New York City
1. When is charging there is a big battery and is locked and the little battery on the bar shows that is charging.
2. Yeah just pul it out if is the wire that came with the phone. The older ones that used to come with the iPods you needed to press.
jimmyjimmy64
Sep 27, 2007
39
Jason
Sorry, one more question. Can I turn the iPhone on while it's plugged in without draining the battery? (i.e. will the power for its operation come from AC or the battery while it's plugged in?)
jimmyjimmy64
Sep 27, 2007
39
So do i have to turn the phone on to see this display? my screen is black right now . . .
thanks
