2 iPhones
jo12jt1
Apr 3, 2010
69
Right folks I need your help? I would think this would be easy to solve but for some reason I can't sort it. I gave my daughter my iPhone 4s and I got another one. For some reason I am getting all her text messages and all her friends messages , I set up another account with the app store with a different email address bit still get the same outcome, all very well but I do not want to hear all about my daughters nights out and her friends problems. Can you please help me
owieh
Jul 15, 2010
481
60
Sheffield, UK
twitter.com
Go to your phone's Settings > Messages > Receive At
And see if it's similar to your daughter's. Make sure with her, the one listed there is her number and the new account... Then ask her to tell her friends to send to that number.
Hope it helps.
Owie
AyaSoraya
Dec 11, 2011
I forgot my passcode lock so how to solve this problem,Thanks
Apple iAddicted
Feb 20, 2012
269
27
Try a factory reset and redo the old 4s just for your daughter that may help.
Sent from my 32GB iPhone 4s on iOS 5.1.1
The ONLY thing better than an iPhone is the newer iPhone!
edtrud
Jul 3, 2011
you do not need to restore your iPhone. if it jailboken then you can ssh into it and delete keychains file and passcode will be gone
