2 phone lines in 1 SIM
misopi
May 28, 2012
Hi,
I use a SIM card with 2 phone numbers assigned to (called Plus Turbo by Plus - Polish operator) businesss and private. SIM software allows me to change a line from businesss to private and the other way. In order to do that you have to access menu: Settings > Phone >SIM Applications > Plus Turbo > Change to ... - this part of menu is assigned to SIM card. To change line you currently use you have to access Settings > General > About. Then you see Network - Plus; Line - Private or Business.
Is there any way to have the line displayed on Springboard instead of operator name? In my former phones (Nokia, SE) it was done automatically so I was always aware which line do I use.
iPhone 4s 5.1.1. Jailbraked.
Thanks,
Michael
iphonewarrior
13,847
699
Thanks,
Michael
I don't think this possible, if it is I've never heard or seen it before.
