2 Questions please help!
Techno_man
Oct 27, 2007
56
First my safari crashes a lot when browsing! Is there something i can download or do to solve this crashing thing
Then i can't play flash on my iPhone sometines i need flash players to browse some websites but i can't so is there any solution also ? I can't download it from the macromedia web it won't work
Any help would be appreciated
Those are both commonly discussed issues. Search around next time.
Safari frequently crashed in all of the firmwares up to 1.0.2. The problem is fixed in 1.1.1. 1.1.2. Upgrade.
The iPhone does not support flash. You cannot download from Safari, hence you cannot download it via Macromedia. There is not a mod that will fix this. Deal.
- John
Techno_man
Oct 27, 2007
56
Thx for answering but i cannot update my 1.02 Firmware since it's ulocked and using a different carrier so if i update it will be bricked :(
Ah. I see.
Sorry to hear about that.
- John
termleech
Sep 7, 2007
1,154
McPherson, KS
You actually can upgrade. You just have to revirginize the phone, the upgrade, then apply the patches. Do a quick search, it's been convered a few times on how to do it.
Techno_man
Oct 27, 2007
56
I searched and got the link thanks!
Freya
Nov 9, 2007
9
One more reason not to hack iPhone...
Techno_man
Oct 27, 2007
56
Dude it works! i am running now on 1.1.1 ! some great improvements ! thanks to a simple tutorial that i found on this forum :)
djw31
Oct 13, 2007
what exactly did you search under because im looking to do the same thing you had to do?
djw31
Oct 13, 2007
never mind got everything figured out.
