2 rings then only vibrate?
Rhinohd
Sep 20, 2007
105
My phone rings twice then vibrates only. Cant seem to figure out how to change this. Any help would be great. If I can change it at all...
FrankieG889D
Mar 23, 2009
232
I don't think theres a way to change that... you might have a defective phone though.
Phxblue
Apr 13, 2008
467
The Valley, AZ
Always Always Always do a restore on the phone first when you see a software hiccup. That usually fixes the problem and will save you the headache of trying to return the phone.
Rhinohd
Sep 20, 2007
105
Thats what I did and its fine. I know most issues are software related. Thanks!
soorg
Jul 2, 2009
Is there another way? I get many rings with the standard ringtones, but I made a custom one, and it only rings twice before going to vibrate.
soorg
Jul 2, 2009
It's the same file I used for my old iPhone, where it was working fine.
soorg
Jul 2, 2009
Don't want to restore the phone and lose all my files.
Smalarz88
Jul 2, 2009
I had the same problem. I used the same ringtoned since the original iPhone. When I got the 3g s it would ring twiceand start to vibrate. I had to use a program to loop the ringtoned to fix the problem.
NHenry5
Jun 19, 2009
32
all my custom ring tones work perfectly.
soorg
Jul 2, 2009
Did a full restore, and same problem persists!
