3.0 compatible iPhone video recorder
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
For those like myself who prefer iPhone video recorder over cycorder. You can't install it through cydia regularly. You have to open cydia, click on manage and then add it as source. This is what your going to add:
iPhonevideorecorder.com/3/
this version is 3G 3.0 compatible and will record 15 times for 30 seconds. If u have the password you will have the full feature. I'm not sure posting the code is acceptable so I won't but there are ways to find it via google search. There u go!
Jun 18, 2009
just wondering, why would you prefer iPhone video recorder over cycorder?
BigCiX
Jul 11, 2008
1,445
Bakersfield, CA
When I was using cycorder the framespeed was choppy. This one is much smoother. Also cycorder didn't give me the option to send via email or upload to YouTube.
KabaModern
Mar 31, 2008
4,549
32
Philadelphia, Pennsylvania
Thanks, I'll give this a try! I noticed Cycorder is quite choppy.
You're correct. Finding the registration code, is...well, way too easy. :cool:
RichR
Sep 30, 2007
181
youtube upload on iPhone videorecorder does not work because youtube now requires an authorized site to upload.
Aug 13, 2009
Hi
Do you know if there is a fix or a work around for this? Did you hear this from the developer directly?
Does anybody know anotehr way to upload these files to youtube?
