3.0 Cydia Apps/hacks compatibillity thread
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Post Cydia apps that are working or not working with 3.0. I'll try to keep this 1st post up to date.
Combatible:
Winterboard
5 icon dock
cycorder
openSSH
SBsettings (updated to 3.0 - now includes battery % icon)
iGlass Sol theme
iFile
Categories
xxxxxxxxxx
asVibra - (makes notification vibration longer) works / updated to 3.0
PDAnet
mxtube
statusnotifier - icons work / utility app doesn not
dTunes
asBattery
A Better Tap to Unlock
Backward Compatibility
Beautiful White Dots
Cycorder
Digital Signal bars
reflective dock
123spoof
rename
tricker3G - works great with SlingPlayer!
iFMyLife
intelliscreen -- buggy / use at own risk
Five Column Springboard
Supreme preferences
Backgrounder - updated to 3.0 on 6/26/09
iBlank
notifier 3.0
Not compatible:
snapsure: crashes to springboard
LockDockBar - puts springboard into safe mode
Mobilefinder - Not working (crashed to springboard)
Pockettouch - will not install
fontswap - not working
Live Clock-not working
Temp on status bar- No Dice
iPhone modem
TuneWiki
customize
SixRows
hClipboard
logome
iEasyCamera
gPower
cbyrlee
Jan 6, 2008
iFile - Working
Categories - Working
Every winterboard theme I tried worked, but I tried nothing fancy like iNav.
Five Icon Dock - installed but spacing between icons was all f*d up, I uninstalled
Five Column Springboard will not install :(
Pockettouch - will not install :( one of my favorite
perks
Oct 28, 2008
44
fontswap doesn't seem to work, i installed font but it doesn't change.
Barachus
Aug 28, 2008
35
winterboard seems to randomly ignore a few theme icons and just use the default Apple ones
Adam1389
Nov 20, 2008
588
Ilwaco, WA
Just tried Backgrounder, no go there. Its handy for IM apps, at least until they all come out with push. Works great for Pandora (When they get it working anyhow)
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
I tried to install "fivecolumnrow" and Cydia won't even give me the option to try to install it. I've never seen that before.
Ldc4S
Aug 7, 2007
73
Dallas, Tx
Winterboard kept giving me the sad mac face and had to restart so i had to uninstall. Using Lockdown as well causes the same. Does xxxxxxxxxx still work even with the old patch?
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Need some help on the names of two apps...
The first one would allow you to uninstall a Cydia app by holding your finger on it and hitting the X (like the Apple apps).
The other would put that days calendar entries on the lock screen (NOT intelliscreen).
Thanks.
Adam1389
Nov 20, 2008
588
Ilwaco, WA
Thanks.
Cydelete I think is the name of the first one, not sure the second.
Kuntry
Mar 26, 2009
318
Las Vegas
Thanks.
cydelete and lock calendar. lock calendar worked on beta 5 but i had to switch the viewing time period to a month for anything to show up...i only had it jailbroken for a few days then i installed 3.0 GM.
jaxdvd
Feb 21, 2009
iRealSMS
Just grabbed the iRealSMS Beta from their sites beta repository and its great as it was before and they say it has MMS support but still in beta of course....I'm on ATT so I wouldn't know bout the mms anyways :(
johnlt
Feb 5, 2009
74
Five Icon Dock-works perfect
Font Swap- Not Working
efuseakay
Nov 11, 2008
864
99
We should get a better formatted list... things that work under a Work category, and things that don't, under a "Don't" category.
Would be easier for people to search IMO... good deal for starting this thread!
Booya! Awesome! :D
iErik
Oct 27, 2007
1,221
72
Las Vegas, NV
Better? (check first post)
