3G case fit 3GS?
PDACPA
Jan 16, 2008
542
The 3GS looks a bit more rounded, do the old 3G cases fit the 3GS? I have the incase slider on my 3G
psylichon
Oct 31, 2007
16,591
751
40
Philly
Yes, they work fine. I'm using a Seidio Innocase II for 3G and it fits perfectly.
JoeT
Dec 18, 2007
911
Tampa, FL
Everything for the 3G should work with/fit the 3GS.
PDACPA
Jan 16, 2008
542
Someone posted their 32g white one and it just looked a little more round on the corners which made me suspect.
I am going to need a new case as I am giving my wife the 3G but she might not go for the black incaseslider so even if it did fit then I have to get 2 new ones anyways!
Blueline29
Jun 12, 2009
98
St. Louis
I'm using a 3G case on my white 3GS right now & it's working wonderfully. It's not the same one I'll be using once my Capsule Rebel (Cherry) arrives in the mail, but it's working well for the moment.
reddot
Mar 27, 2010
Im thinking about getting new case for 3GS I used to have black case from incase what kind of case is everyone using?
iTim
Mar 21, 2010
445
Los Angeles, Ca
Reddot, this thread is almost 1 year old. I would start a new thread to ask your question as most read the first post and anwer the original question and are not looking for new questions.
I will answer your question though. I'm not using a case. :)
reddot
Mar 27, 2010
Thanks iTim, Ill start a new one! (^_^)
