3G 'Creaks' when I squeeze it...
I'll first start by saying save the innuendo jokes.
Moving on, I've had my white 3G for about a month and a half, maybe 2 months now, and I already notice some hairline cracks around the usual places.
I don't know if this is the cause, but I was wondering if it's normal for the phone to kind of 'tik' when you squeeze it from the sides. It sounds like the plastic casing is just moving a bit.
Any thoughts?
psylichon
Oct 31, 2007
16,591
751
41
Philly
Plastic creaks. I'm not sure there is a way to seal a plastic case that will not eventually squeak and creak in some way.
xxsirvtecxx
Mar 3, 2008
65
Milwaukee, WI
first of all why are you squeezing it that hard lol...and also don't squeeze it, its not like the other one where it was made of metal, its made of plastic, there are seals around the whole casing to stop the light leakage, and the more you sqeeze it the more you start breaking down the seal.
chrismmm
Dec 27, 2007
612
Gwinnett, Georgia
i am missing something here! why are you squeezing it? You need a case or skin or just a habit, is it slippin outta your hands .. ?
