3G unlock SIM card recomendation and a question for Hungarians
Huncowboy
Jul 20, 2008
69
Hi,
Q1:
Any recommendation for a hardware unlock? I have seen several ones on ebay but then I have read here that some people got their sim card stuck in the 3G.
Q2:
For those Hungarian readers if there are any. I am heading home in a week and I have a Domino card (T-mobile pay as you go) that I always use when I visit to avoid roaming charges. I can buy data for that card for pretty cheap. Would my 3G's get internet with that card? If so is it Edge? Because if it does not get any internet then I will just use my old cell and not even worry about unlocking my iPhone.
Thanks! Koszi!
Sep 21, 2008
22
I can recommend the iPhonesimfreer.com thing. Works for me, iPhone 3G.
Huncowboy
Jul 20, 2008
69
Thanks! I already ended up ordering a different one as I could not wait. I will have to try that now.
Another Q: Do you need to change settings for the internet to work?
gadha
Mar 25, 2008
How long have you been using it for? Do you ever lose the network connection?
Did you have to cut the sim?
