3G Unrestrictor NOW AVAILABLE!
randyw
Jun 28, 2009
So will incease download speed or just allow you download larger files?
mbhullar
Jul 20, 2009
Short Video tutorial for not so tech savvy 3G Unrestrictor
I've created a video tutorial for 3G Unrestrictor application. The Video is available at:
Mandeep
morth58
Mar 17, 2008
174
that video of slingplayer looks so much better than my Orb on true WiFi.
Im have to get a slingplayer now.
artap99
Jul 4, 2009
17
My Facebook application doesn't have a badge on it when I have notifications. Is that a hack or something different from the official application?
Oct 26, 2007
11
Sorry to take this thread on the other topic, but if someone can tell me what is that apps name in video where he slides his finger at the top and some options comes up ?
Oct 26, 2007
11
thanks so much for your quick reply. It is really a helpful setting to have it.
thanks once again.
Dec 15, 2008
5,386
340
Pensacola, FL
Is 3G Unrestrictor worth buying?
Also, I see the 3G Unrestrictor for xxxxxxx. It wont let me install it though. It says The requested modifications cannot be applied due to required dependencies or conflicts that cannot be automatically found or fixed.
--Actually, I found out reason. FW 3.0.1 is not supported--
In any case, can I get opinions on 3G unrestrictor? The paid version, that is.
Jun 19, 2007
33,493
4,550
Upper Marlboro, MD
If you get decent 3g reception, then I think that 3Gunrestrictor is definitely worth having for apps such as Slingbox Mobile, etc.
Dec 15, 2008
5,386
340
Pensacola, FL
3G reception? I am not to sure on this. But I did hear that 3G unrestrictor is good to trick programs into thinking your on wifi, is this correct? So, I can use youtube, etc?
Also, do you have xxxxxxx installed? I just saw an app that disables the ipod and safari rotation. That's sweet.
scottjf8
Aug 12, 2008
528
Just got this. It buffers a lot :(
Using Slingbox.
scottjf8
Aug 12, 2008
528
Ok after a few buffers, it seems to be working really well now.
Quality is really awesome.
Backgrounder works with Slingplayer too!
Jun 19, 2007
33,493
4,550
Upper Marlboro, MD
You can get Rotation Inhibitor for free via Cydia. You don't need a cracked version.
Jun 19, 2007
33,493
4,550
Upper Marlboro, MD
Pay the small price and support the developer.
scottjf8
Aug 12, 2008
528
I just tried it ... first off, i'm on 3.0.1 and it works just fine. I paid using Amazon (dude, it's 2 bucks!) and it took a second to authorize. Then it installed, resprung, and I added Slingplayer to the list. Went back to Sling, and it worked as if I was on WiFi!
