3GS Power button and Home button getting hard to press
Little-Acorn
Feb 6, 2012
Is there any way to fix these two buttons? They still work, but are getting very hard to press.
What's a mother to do?
Little-Acorn
Feb 6, 2012
I had this same problem. Luckily my iPhone still had its warranty and Apple just swapped iPhones for me.
I did see this article recently on Lifehacker which gives you a tip on how to fix your home button, http://lifehacker.com/5881404/wd 40-will-loosen-up-your-unresponsive-iphones-home-button-in-seconds
Hmmm, sounds do-able, thanks!
At Frys you can get a spray can of something called "Electronic Contact Cleaner", it's designed to be sprayed on electronics (obviously), and says it won't hurt them.
Also a good thing to try, maybe?
