4.3.4
cdelauz
Jul 13, 2008
291
Any word on when the patch for the PDF exploit is suppose to come out?
Chex
Dec 17, 2008
592
PA
I have had the PDF Patch installed for 2 weeks! :)
Sent from my iPhone 5 using iCafe app
iphonewarrior
13,847
699
Besides making the device unjailbreakable, that is all it does.
That doesn't make sense? The jailbreak is PDF based and the device has to be jailbroken in order for you to install the patch, which protects the user from other PDF based (harmful) exploits via the patch in Cydia.
It's kind of silly but no one would have known about the PDF vulnerability until jailbreakme 3.0 was released, it wouldn't have mattered.
To clarify and elaborate: Apple was alerted about the vulnerability when it was utilized in a jailbreak. Since it could be used maliciously, however unlikely that is, Apple released a security update (firmware 4.3.4) to patch it. If you install the update, jailbreakme.com won't work. Since the 4.3.4 update does nothing but fix the exploit, you can have the best of both worlds by jailbreaking 4.3.3 and then installing the PDF patch in Cydia.
Lon
Jun 5, 2010
2,946
132
Alaska
Just for information then. Can the iPhone or iPad 1 still be jail broken on 4.3.4 using Redsn0w, since it is not using the PDF vulnerability?
Lon
Jun 5, 2010
2,946
132
Alaska
So the PDF "fix" in 4.3.4 did more than just fix the PDF vulnerability, since Redsn0w did not exploit that vulnerability. That was a question I think!
iphonewarrior
13,847
699
Each firmware update throws in a new problem, most if not all recent firmware updates have been jailbreakable, but tethered initially. I see no requirement to update to 4.3.4 when I can get the PDF patch from Cydia for 4.3.3.
