5/5s bulge vulnerability?
Rafagon
Dec 7, 2011
7,566
1,252
44
Miami, Florida
I had this issue on my 5, and today I noticed it is starting on my 5s: the phone bulges outward at the center ever so slightly, so that right where the SIM tray is, it is starting to separate from the screen.
The only explanation that makes any sense is that the case is gripping it too tightly and forcing it to curve that way, little by little.
I had an Otterbox with the 5, but now I'm using the Speck CandyShell case on my 5s. They both wrap around the iPhone very tightly, to it is conceivable that it's slowly causing the phone to curve inwards.
Any ideas or suggestions? Besides the obvious, which I have already done—stopped using the case until I determine what's causing this.
chris
Administrator
Administrator
Jun 10, 2006
11,812
1,778
Long Island, NY
Are you sure you don't have an iPhone 6 with the curved screen?:) If a case is causing the screen and/or phone to bend, I'd question the manufacturing of the iPhone, at least your particular iPhone. No case or 'squeezing' should causing the center to bulge out.
Mind sharing a photo of it?
28,365
5,506
I've never had this happen. I don't see how a case could cause it. It sounds like both phones were either defective or it is the result of cumulative stress such as back pocket carrying as mentioned above.
Rafagon
Dec 7, 2011
7,566
1,252
44
Miami, Florida
So it must be something I'm doing—something I also did with my iPhone 5.
It becomes more noticeable when I press down on one side, as you can see.
I never use my back pockets... :(
The Speck case exhibits similar curvature:
Rafagon
Dec 7, 2011
7,566
1,252
44
Miami, Florida
I only use the front pocket, but I'll stop using *it* as well. Just in case...
Before I make it worse!
ricks2gtouch
Feb 20, 2009
585
162
43
Ok. How many of you took your phone out of the case to check it? I did. No abnormality found. I use a Magpul field case and mine stays in my front pocket.
Do you hold it in landscape a lot? Like when gaming?
Target
Oct 16, 2008
1,139
168
The Great State of WV.
My niece had that happen. It was her battery getting hot and expanding. Just separated that glass at the screen's edge. It was a defective battery.
Target
Sent from iPhone 5 using The New iCafe app
Rafagon
Dec 7, 2011
7,566
1,252
44
Miami, Florida
Nope, that's definitely not it. I'm not a big gamer. The only game that requires landscape that I played for any significant amount of time was Angry Birds Go!, for about two or three weeks, before I got tired of it. I launched the game anyhow, just now, to see how I hold the phone for gameplay, and it does not involve any forces that could possibly result in the phone getting bent.
The only game I play on a regular and on-going basis is Words With Friends...
28,365
5,506
I was thinking of that as a possibility earlier. I'm probably a little paranoid, but that would scare me. I had a portable battery charger that was just over a year old when it started making a quiet buzzing sound. It still worked great, but I immediately threw it away because I didn't want to have to worry about it exploding. My dad has shown me some of his RC airplane batteries that have expanded, and I guess he still uses them since he didn't throw them away, but I wouldn't chance it.
@Rafagon I'd have Apple check it out and let you know if it's the battery. They'll replace it for free either way.
28,365
5,506
Seems odd he'd have 2 phones with a battery that causes the phone to bend.
I was leaning towards something he was doing at first as well since it does seem unlikely that two in a row would have defective batteries, but it is possible. Lithium-ion polymer batteries have lots of folded layers and when they expand inside an electronic device, they push up on the screen and other hardware unevenly giving it a bent appearance. The expansion is not repairable.
Jan 13, 2014
14
Did OP keep the ip where heat can absorb to the ip? Car dashboard maybe during driving to work etc? If its become daily, sure heat from the sun to the ip can cause it expand and bend..just my theory..
Rafagon
Dec 7, 2011
7,566
1,252
44
Miami, Florida
Did OP keep the ip where heat can absorb to the ip? Car dashboard maybe during driving to work etc? If its become daily, sure heat from the sun to the ip can cause it expand and bend..just my teory..
Thank you for your input:) the OP rarely exposes his IP to sunlight. The OP and his IP are almost always indoors.
