7.1.2 JB problems
ironlungakc
Aug 26, 2007
94
On 7.1.2 and trying to JB...
Following the instructions, it downloads, my phone reboots but no cydia (just the pangu icon)...then the computer says jailbreak timeout in red and done.
Ive tried a couple times and keep getting the same thing.
Any suggestions?
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
Are you setting the system date to June 2?
Did you do your 7.1.2 update OTA?
Are you tapping the Pangu icon when prompted to?
Also, try the jailbreak in airplane mode.
Dec 15, 2008
5,386
340
Pensacola, FL
Again I will provide my solution that I believe fixed my issue. Well, I will start with a question. Are you exiting the settings app after changing the system date? Because I did this, the jailbreak continued to fail and give me errors / not show Cydia afterwards.
Ohh I now see this hasn't updated for 12 days or so. I hope they were able to fix it and get jailbroken.
