8gb iPhone - Question about the capacity
beautifulliar
Jun 10, 2007
90
Are you able to use up the entire 8GB with music? Or do you need to leave a few gigs free for the phone to run smoothly? Yesterday I added a lot of music to my iPhone. I ended up with a little under 2gb free. I've noticed that since I've done that that the iPhone freezes sometimes. It never did that before. Do you need to leave a certain amount free in order for the iPhone to run smoothly?
socalkevin21
Jul 8, 2007
114
The amount needed for it to run smoothly should be used up in that .7 GB that they take from you to begin with. If you noted, the device is only capable of 7.3 GB of usable memory. I only have about 50 songs on mine and 3 pictures and mine freezes every now and then.
beautifulliar
Jun 10, 2007
90
K, I'll add more music then :)
Right now I have 466 songs, 24 videos & 762 pictures.
