99% vs. 100%
trnsilver
Feb 2, 2008
1,124
When charging my phone overnight, sometimes it does not charge to 100% but rather 99%. This is not a big deal in the grand scheme of things - but I am curious if it speaks to a bad battery or if others have experienced this same thing?
I saw this a few times on my V1 when I was jailbroken and had battery percentage enabled - I think disconnecting the iPhone from the dock/cable and then reconnecting it and letting it charge for another minute fixed it.
cliffeman
Oct 13, 2007
2,142
80
Feenix, Amizona
mine has been doing that even before i jailbroke it. I've seen it only charge to 96%. Like Lincoln said, i unplugged it and plugged it back in. Then it fully charged.
stevetim
Jul 20, 2007
606
Hopefully it is just the fact that all the cells in the battery aren't fully chargeable...yet. With more use they should all be able to hold a 100% charge because I've seen this a couple times on my 2nd S(went from 16gb to 32gb phone).
Battery life is actually quite good even when it happens.
trnsilver
Feb 2, 2008
1,124
Yes, battery life is fine. On 3G all day today with Push notifications & 15 min fetch e-mail. Checked about 20 e-mails so far and downloaded an app and at 93%.
No location services, no wi-fi.
Just thought it was weird that it won't go to 100% all the time.
debest74
May 4, 2007
244
Palo Alto, CA
This was happening 2 with my iPhone and I remembered that this happened with my macbook pro as well. I did a little "research" on google and what i needed 2 do was 2 let the battery go down past 80% or so, then plug it back in a let it charge... i did that and the battery charged fully... i did the same with my iPhone and it worked, my battery charged up 100%
p09
Jun 30, 2009
20
Never had this problem with my iPod Touch or my iPhone 3GS. Seems to always charge to 100%. Odd!
beautifulliar
Jun 10, 2007
90
It seems to take awhile to jump from 99% to 100%. But, it does fully charge if you leave it charging long enough.
HUNTER1
May 28, 2009
404
I had mine like that this morning. It always charged up to 100% and very quick. I thought it was fully charged and I unplugged it, it was only 99% and I thought, what was wrong? I plugged it back in and it instantly said 100% and after few seconds it came down to 99%. I unplugged and plugged it back in and said 100% again and pulled it out. I'm sure it's fully charged and it's holding it's charged very well. I started this morning fully charged, I watched full 2 hour movie and some web browsing and only used 10%. I think that's good.
6,682
49
On my 3G, (and others have stated this too) I get the plug icon at 99%. It usually takes another 30-50 minutes to charge that last 1%. The closer you are to topping off, the longer it takes to charge.
reboot your phone every 3 days or so, keep the phone topped off as much as you can, and drain to 20% and fully charge once a month and it should be fine.
HUNTER1
May 28, 2009
404
You mean rebooting by turning it off completely or how?
psylichon
Oct 31, 2007
16,591
751
41
Philly
This is why I turned off battery %. I don't think that anomaly indicates anything other than the fact that it's difficult to precisely pinpoint the actual charge of a battery, and offsets are likely to occur.
HUNTER1
May 28, 2009
404
You're right. I had this turned off until I decided to watch how this function works, one less thing to worry about.
trnsilver
Feb 2, 2008
1,124
Mine was at 100% this morning. Turned off my alarm and checked one e-mail and it was at 99%.
