a easy way to fade in and out for ringtones.
tjespo22
Jul 20, 2007
50
anyone know of a easy way? i use garage band to cut the song length but what about fade in and out? can u do it in garage band? thanks.
Lips2000
Jun 4, 2007
100
Houston, TX
Sure can...
Drag the mp3 to a track and then cut it to size. (I leave about 1 second on each end for the fade.)
Then show the volume track and adjust the volume line down in front of the track by clicking on the blue line (volume) and dragging it to the bottom of the volume track. Do this at the other end and there you go.
It will create a line that looks kinda like __/------\___
Mark
420greg
Jun 26, 2007
845
Orlando, Florida
Just change track pan to track volume in the pull down menu left of the track.
There should now be a green line going through the track. Just click on it and move it down to fade out. Click again if you want a sharper fall off. Just mess with it a little. Its easy.
