A few questions about coverflow?
Sep 14, 2007
when your looking at specific playlists and you go into coverflow mode, does it only show you album artwork for THAT playlist, or for all of your songs?
Also does coverflow work the same way it does in iTunes? Because I know that in iTunes when your viewing a specific playlist, when you go into coverflow mode it allows you to only view artwork for those specific tracks.
adseguy
401
Cover flow mode does not work by what playlist you are in. It just shows all your albums by every artist and you go from there.
Dawgfan
Jul 27, 2007
347
Atlanta, GA
If iTunes does not have the cover, try Amazon.com and just copy it into the artwork area.
bambam26
Sep 7, 2007
119
Atlanta, GA
I don't buy music so my cover flow looked very weak. Now maybe it will live up the hype for me.
