a little problem with WiFi
fredman21
Apr 7, 2009
i activate wifi in my house and sometimes the IP address and router are incorrect like the phone isn't picking up the right signal but it still says its my network and i hit renew lease and it picks up the correct one....someone hlp me out to figure why it does this?
iNinja
Aug 8, 2008
3,985
20
UK
Which firmware are you running? If your still on the 2.x firmwares, i had a similar problem. Reset your router and then through your pc/mac, go into your router settings and make sure your encription is not WEP. Change it, or make sure it is WEP2 or higher. That should fix it!
Quake97
Jul 10, 2007
522
Philly Burbs
I've seen this on wired networks too. What happens is your device sends an old address to your router, which denied it. You have to refresh/repair the connection to fix it.
Joe
