accidentily installed 1.1.1 summerboard on 1.0 phone
allur3
Sep 25, 2007
hi i accidentily tried to install the new summerboard for 1.1.1 on my 1.0 iPhone and now i can't add or delete any applications. anyone know how to fix this?
iMerlin
Sep 20, 2007
662
Algonquin, IL
Allur, I did this accidentally also, after I did my dock was at the top of the springboard. I simply went back into the installer app, and uninstalled Summerboard, then rebooted the iPhone and it was back to normal. Hope this helps.
allur3
Sep 25, 2007
i actually installed it with ibrickr and i already removed the application, but I can't add any or delete any now.
iMerlin
Sep 20, 2007
662
Algonquin, IL
yeah i can't add or delete any apps using ibrickr anymore
Did you try to shut down iBrickr and try to start it up again? Did you reboot the iPhone? If you did all that, Im not sure what else you could try. I just recently started using iBrickr and ran into your problem once before and was able to resolve the issue with a reboot.
