accidently deleted iTunes music from computer
fee
Oct 27, 2010
Ok I was having trouble with hard disc space and so I tried to move my iTunes to external hard drive in which somehow I deleted the entire music library off my computer and its not on the hard drive NOW the only place I have all my music stored is on my iPhone and Im in the process of getting new computer and Im hoping that I will be able to get my music off iPhone into new iTunes library
IS THIS POSSIBLE?
Lunfai
Sep 16, 2010
442
IS THIS POSSIBLE?
Plug your iPhone in and cancel the sync and the right click your iPhone in the left pane where it has your iPhone name, and there should be a 'transfer purchases' option or something named similar, click that and it might restore your music back onto your computer library, ENJOY! Tell me if it works, I know it does for apps.
Or if your jailbroken get iPhone explorer on your computer or use ssh and copy the music folder in your library on your phone to your computer and your sorted, but this could take a long time, but 100% do-able and works.
Sent from my iPhone using iCafe
28,365
5,506
glsda
Oct 17, 2007
1,440
50
California
Some what similar problem I was in iTunes and created a new play list and transferred, clicked and dragged the songs I wanted into it from the music play list. I then highlight, in the music play list those songs I transferred and deleted them. I had the option of moving them to the iTunes library or the recycle bin. I know, stupid, stupid I selected the recycle bin. It deleted those songs from all of the other play lists that I had previously moved them to. I tried to find a delete undo in the iTunes toolbar but no such luck. I did a search under iTunes help and again no such luck. I went to my recycle bin on my desk top and there they were so I clicked restore thinking they would be restored to my iTunes library. No such luck. I know they are on my computer some where. I use a PC. Any suggestions on how I might find them and restore them to my library. If I could find them I think I could import them into mu iTunes library. So far my thinking hasn't helped much so any advice would be appreciated. Jerry
Update I found where the songs were stored on my hard drive and have imported them back into iTunes, The pain is I have to recreate my play lists.
justinxtreme
Sep 22, 2009
181
Lunfai's method only works if you purchased your music from the iTunes Store
The iPhoneBrowser method is a bit messy
Like I said in other posts, use SharePod for music not from iTunes since it organizes your music for you along with copying it to your computer (to any folder you want) otherwise use Transfer Purchases in iTunes
btitus
Apr 7, 2009
501
26
North Carolina
Can you not go to the recycle bin and restore them to their original place?
justinxtreme
Sep 22, 2009
181
All you have to do is have the iTunes library file
The original one.
Otherwise you can manually add them, File > Add File or Add Folder
For Album Artwork (requires iTunes account)
Select all songs using CTRL + A then right click and Get Album Artwork
glsda
Oct 17, 2007
1,440
50
California
The original one.
Select all songs using CTRL + A then right click and Get Album Artwork[/Q
Where is the iTunes Library File located?
glsda
Oct 17, 2007
1,440
50
California
I found my iTunes library and restored all the songs I had deleted. The only aggravation is I had to manually recreate my playlists . If that is the biggest problem I have then I am blessed.
Old Gregg
Dec 18, 2011
Ypsilanti, Michigan
PLEASE READ THIS WILL HELP:
There is a program called CopyTrans (and its free btw)
Install this and i guarentee it will help. (sorry if i sound like a commercial lol) -- --
(o) (o)
------------ (face)
but anyways i accidentally deleted some of my favorite songs. i hadnt done anything for a looooooonnnng time because i thought i wuz gonna have to go through a bunch of crap just to get my songs back. but 2day i finally was looking and decided to install this program. (btw it might be slightly hard to install but it just brings up a few windows but no big deal)WOW was i surprised when i used it and got my stuff back in tha blink of a eye. email me anybody if this helps because this program is the best thang (the best part is that it is totally free.)
Jun 19, 2007
33,478
4,542
Upper Marlboro, MD
(o) (o)
------------ (face)
Formatting edited..
(o) (o)
------------ (face)
Thanks so much! :) I followed your suggestion after I unwittingly deleted some albums in my PC. CopyTrans did a terrific job! ;)
ToddCarey
Mar 31, 2012
I think you need a similar software:
[spam deleted]
