Activate iPhone for AT&T after modding?
umakbill
Aug 17, 2007
39
If I mod my iPhone and trick it into thinking it's activated, is there a way for me to activate it on AT&T's network afterward? I've heard that updating the firmware will remove all mods, but will my iPhone still work on EDGE and as an actual cell phone if I mod it before actual activation? In other words: can I un-activate it after modding so I can activate it for AT&T?
SiLeNtKiLLa
Jul 4, 2007
134
Atlanta
Yes! You may have to restore to re-activate any way, but its possible.
umakbill
Aug 17, 2007
39
alright, I'm actually trying to so it right now, but when my phone reconnects to iTunes it unlocks it! I tried deleting all my backup versions, and I'm doing restore/recovery again, but I just need to find a way to undo the unliocking. That shouldn't be hard, right?
umakbill
Aug 17, 2007
39
:mad: iTunes keeps unlocking it! I deleted all my backups, I'm scared! Is there anywhere with instructions on how to un-unlock an iPhone?!
skiz420
Jul 28, 2007
371
Boston
did you try a full restore by holding power and home until the yellow triangle comes up then pull the usb cord and plug it back in while still holding them then let go... it should say in iTunes that it is in recovery mode and must restore... should set it to factory settings
umakbill
Aug 17, 2007
39
I put it in recovery mode every time, but now I got it back to the "Activate iPhone" screen. (After 4 long tries) I'm now trying to activate using iTunes, but I keep getting an error saying "We could not complete your iTunes Store request. A secure network connection could not be established. Make sure SSL 3.0 or TSL 1.0 is enabled in the Internet Options control panel, then try again." I checked Apple.com, checked my firewall, my settings, Control Panel, and #iPhone. I ran a diagnostic on iTunes and it said it was fine. I can access the iTunes store, but not activate my iPhone. I even reinstalled my iTunes, rebooted, unistalled iTunes, installed newer iTunes, rebooted, and reinstalled that. I'm going to kill someone.
skiz420
Jul 28, 2007
371
Boston
ok shut off norton, mcafee, zonealarm, or any other software based firewall.. or try on another pc
umakbill
Aug 17, 2007
39
I shut off all my firewalls and tried again, no luck. I'm gunna call AT&T to activate, or use my friend's laptop.
Tinman
4,334
183
Aridzona
Also make sure that your hosts file doesn't contain any entries from when you originally unlocked it. Like this:
127.0.0.1 albert.apple.com
This will prevent the iTunes store from being contacted.
Mike
umakbill
Aug 17, 2007
39
I used my friends laptop, it works now. Still don't know what was wrong, but im using the phone to type now, it seems okay.
