Activating the iPhone
afrojefro
Dec 6, 2007
i just have a few questions. do you have to activate it through iTunes or can you have some one activate it at the store like a normal cell phone and about how much does it cost to activate the phone thanks
Griffinaz
Oct 5, 2007
1,046
Phoenix, Arizona
When you purchase the phone it is not activated and you have not yet selected a plan. When you get it home you connect it to iTunes and through that interface you activate it and select the calling/data plan(s) that you want to use. They do not activate it at the store. The activation is free (you already paid for the physical phone) and then you will be billed for your first months use on whichever plan you selected when you activated.
termleech
Sep 7, 2007
1,154
McPherson, KS
The only thing that happens when you buy it in an AT&T store (I don't know about Apple stores), is they will preauthorize you for the phone account. Basically it does the credit check and makes sure you are good to get the account.
