Activation question?
BAD_S197
Nov 2, 2007
When I start going through the activation, can you specify when you want the bill to come? I want the bill to come on/after the 15th of each month. However I was thinking I wouldn't be able to activate it till next week when it was actually the 15th.
thanks
jake
Dragoro
Sep 9, 2007
140
They don't give you that choice, but I aint sure when you activate makes a difference on your billing date.
BAD_S197
Nov 2, 2007
I would assume the billing date would be the same as your activation date.
iFuNk
Oct 25, 2007
93
thanks
jake
Are you already an ATT customer? .. If you are then the bill will come on the same date as your existing billing cycle.
BAD_S197
Nov 2, 2007
I'm currently on Tmobile.
I have a home phone but it's under my gf's name since she only uses it to call Japan. We use cellphones for everything else.
